Element Software networkEvent - Errors observed on interface - AutoSupport Message
Applies to
NetApp Element software 12.5 and later
Event Summary
The network event will be generated for the following network interface errors reported on any of the physical network interfaces used in the storage cluster:
- Received Misses
- Received CRC Errors
- Received Length Errors
- Received Over Errors
- Received Frame Errors
Validate
Find the details of the error and the corresponding interface by checking the Element UI Event Log or the Active IQ Events page
Resolution
Most of the above mentioned errors are caused by any one of the following
- Bad NIC port(s)
- Bad switch side port(s)
- Bad cable between NIC and the switch
Additional Information
additionalInformation_text
