NetApp Knowledge Base
What is Performance Capacity in ONTAP 9 and Unified Manager?
7,111
Visibility:
Votes:
4
Category:
ontap-9
Specialty:
legacy
Last Updated:
Applies to
  • ONTAP 9
  • Active IQ Unified Manager
Answer
  • Performance Capacity is a new feature that ONTAP 9 and Active IQ Unified Manager (AIQUM) together support, which allows you to proactively monitor performance headroom in your storage environment.
  • This feature helps storage administrators address the following concerns:
    • Where is the best place to create a new volume / LUN?
    • Where can this volume / LUN be moved to?
    • Is this cluster over utilized?
    • Is a particular cluster resource over utilized?
    • When will this cluster become over utilized?
Details of Performance Capacity
  • ONTAP measures headroom as a basic calculation per node.
  • AIQUM does more calculations to find the optimal point for CPU and IOPS.
  • This calculation is the point that CPU and IOPS can go the highest before incurring extra storage latency, like the graphic below.
  • For more information, see the following NetApp TechComm TV video on how to use this feature:
