ActiveIQ UM 'Assign System Recommended Performance Service Level' is not adaptive to a highly variable workload
Applies to
- ActiveIQ Unified Manager (AIQUM) 9.6 or later
- Performance Service Level (PSL)
Issue
- A workload in UM has the
Apply System RecommendedPSL assigned
- UM uses artificial intelligence and machine learning to determine the best PSL
- When there is a sudden large data transfer on this workload, the IOPS on this volume increases heavily while the PSL might not be adapted to this
- This will cause in increase in latency on this volume because the PSL is not adjusted to the variable workload
