NetApp Knowledge Base
Stale error state for fans on NSM100 module cause errant fault LED
1,218
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
hw
Last Updated:
Applies to
  • NS224 shelf
  • NSM100 module
Issue
  • Amber fault LED in NSM100 module after reboot, reseat or replacement.
  • EMS warning:
ses.status.fanWarning:notice]: NS224NSM100 (S/N serial) shelf 0 on channel 0x cooling fan warning for Cooling element 1: not operating. This element is on the unknown location.
  • Output of system node run -node <node> -command storage show fault -v indicates one or more fan sensors as OK with FAIL
  • Example:
Fans:
Element Status         Status Bytes  Status Descriptions
11: OK                01,02,86,61   FAIL
12: OK                01,02,79,21
13: OK                01,02,6D,21
14: OK                01,02,7A,21
15: OK                01,02,74,61   FAIL
  • Fans are, however, working correctly, confirmed with system node run -node * -command environment status
  • Example:
Cooling Unit installed element list: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20; with error: none
Cooling Units by element:
[1] 6540 RPM
[2] 6390 RPM
[3] 6650 RPM
[18] 8090 RPM
[19] 8010 RPM
[20] 8000 RPM
  • AutoSupport section STORAGE-SHELF.XML may also show Error Type: ACPP under the affecter NSM module
New to NetApp?
