NetApp Knowledge Base
What are performance archives and how are they triggered?
55,290
Visibility:
Votes:
10
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
ONTAP 9
Answer
  • Performance content is collected and stored (archived) on each system:
    • Metrics like node and volume performance statistics are logged.
    • Data is kept on the root volume for a rolling 28 days by default.
    • Data is constantly logged, so there is no starting or stopping advanced logging.
    • There is minimal overhead to keep latency down.
  • Using the AutoSupport(tm) infrastructure, a Performance Archive can be created and uploaded to NetApp.
  • Performance archives do not replace performance monitoring or help with sizing as they are intended to troubleshoot ONTAP performance issues.
How to upload a Performance Archive?
  1. Confirm the AutoSupport transport is HTTP or HTTPS:
    • Cluster::> autosupport show -fields transport
      node            transport
      node1           https
    • Performance archives are typically 50 MB or bigger when compressed so ONTAP is hard coded to not transmit if transport is SMTP.
    • To switch to HTTPS from SMTP, which does allow larger file sizes to be transferred, use the command: system node autosupport modify -node * -transport https
    • If the transport is SMTP and the other methods do not work or are not allowed in the environment, use the manual method with 7zip files or OneCollect to gather the data.
  1. Run the system node autosupport invoke-performance-archive command:
    • Cluster::> system node autosupport invoke-performance-archive -start-date "11/31/2026 06:00:00" -duration 6h -case-number <case_number> -node *
    • The following are the options for the command:
      • -start-date <"MM/DD/YYYY HH:MM:SS">
        • Timezone will be the filer's time, viewable in event log show output or EMS log or date output.
      • -duration <[ h][ m][ s]> (or -end-date)
      • -node *
      • -case-number
Notes:
  • It is important to note that the maximum duration for any single collection is 6 hours and the recommended sample period is 4 hours.
    • Anything less than 2 hours will miss some hourly counters.
    • The time entered in -start-date should reflect the time in the filer's time zone.
    • The -start-date must be at least the specified -duration hours in the past, otherwise complete time-frame will not be collected.
    • No error message will be displayed indicating that complete -duration was not collected.
  • It is best to start on the top of the hour and end on the top of the hour to capture the hourly counters.
    • The whole cluster must be triggered since workload statistics are measured across the cluster.
    • Ideally getting the hour before and after the performance event is recommended.
    • It is recommended for the Date format to be in quotes.
  1. Use the following commands to view the progress of the Performance Archive upload:
::> autosupport history show-upload-details -node <node name> -seq-num <seq-num>
  • The performance archive will show up on Active IQ for the node on the AutoSupport page.
  • Once the performance archive is uploaded and appears on Active IQ, it will be available after a period of time for Support to review.
What if performance archive does not work?
::> set diagnostic
::*> statistics archive config show
verify field:
Is the Performance Archive Enabled?: true
if false, enable it by running the following command:
::*> statistics archive config modify -is-enabled true
Note: EMS events will also report the following message when the Performance Archive is disabled:
::*> event log show  -event perf*
Time                Node             Severity      Event
INFORMATIONAL perf.ccma.off: Performance archiver is not enable
  • Please make sure that both the state and support parameters of AutoSupport are enabled. If not, use autosupport modify command to allow them.
aff200-2n-dal-1::> autosupport show -node * -fields state,support
node          state  support
aff200-dal-1a enable disable
aff200-dal-1b enable disable
2 entries were displayed.
Example of failure:
    aff200-2n-dal-1::> autosupport show -instance
                                               Node: aff200-dal-1a
                                              State: enable
                                    SMTP Mail Hosts: mailhost
                                       From Address: Postmaster
                               List of To Addresses: -
              (DEPRECATED) List of Noteto Addresses: -
                          List of Partner Addresses: -
        Send AutoSupport Messages to Vendor Support: disable
                        Protocol to Contact Support: https
                         Support URL for HTTP/HTTPS: support.netapp.com/asupprod/post/1.0/postAsup
                         Support URL for HTTP/S PUT: support.netapp.com/put/AsupPut
                                  Support Proxy URL:
                                    Support Address: autosupport@netapp.com
                                   Hostname Subject: false
                            (DEPRECATED) NHT Enable: true
                            Performance Data Enable: true
    aff200-2n-dal-1::> system node autosupport invoke-performance-archive -start-date "10/15/2024 15:00:00" -duration 1h -node aff200-dal-1a  -uri "file:///mroot/etc/log/autosupport/perfachivefile1"
    The AutoSupport was successfully invoked on node "aff200-dal-1a" (sequence number: 134).
    AutoSupport will be saved to mroot/etc/log/autosupport/perfachivefile1.7z.
    aff200-2n-dal-1::> autosupport history show -node aff200-dal-1a -seq-num 134
                 Seq                                    Attempt  Percent  Last
    Node         Num   Destination Status               Count    Complete Update
    aff200-dal-1a
                 134
                       retransmit  ignore               -        -        10/15/2024 16:17:52
      Why would perfstat be needed?
      • Support will request a perfstat.
      • On ONTAP releases up to 9.5, some data may be missing and Support will ask for a perfsat.
      • Only gather if requested by Support.
      • Sometimes the sales team may request to gather performance data for sizing.
      How can a storage administrator look at the content within a performance archive?
      How long the performance test should be running?
      • For optimal results, it is advisable to ensure that the performance test runs for at least 10-15 minutes.
      • However, running the test for a longer duration is even better as it allows for more comprehensive data collection and measurement.
      • This extended duration helps in capturing a more accurate representation of the system's performance under sustained workload conditions.
      Additional Information
      additionalInformation_text
