NetApp Knowledge Base
QoS Limits causing high volume latency
13,621
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
Perf
Last Updated:
Applies to
  • ONTAP 9
  • ONTAP Select 9.12.1 and higher
  • AFF Series
  • FAS Series
  • Cloud Volumes ONTAP (CVO)
  • Quality of Service (QoS)
  • Google Cloud NetApp Volumes
Issue
  • Elevated LUN, Volume, or Qtree latency observed once QoS limits are reached
  • As workloads change, QoS limits may need to be adjusted to help manage client performance expectations
  • The following alert may be seen from Active IQ Unified Manager: Event alert, Workload Logical Unit Number (LUN) latency threshold breached, defined by Performance Service Level Policy.
  • The latency will be seen in the QoS Max column of qos statistics volume latency show:
::> qos statistics volume latency show -volume qostest -vserver testsvm
Workload            ID    Latency    Network    Cluster       Data       Disk    QoS Max    QoS Min      NVRAM
-total-              -   646.73ms  1377.00us        0ms   262.00us     9.49ms   635.60ms        0ms        0ms
qostest-wid23..  23350   646.73ms  1377.00us        0ms   262.00us     9.49ms   635.60ms        0ms        0ms
-total-              -   634.31ms  1430.00us        0ms   263.00us     6.78ms   625.83ms        0ms        0ms
qostest-wid23..  23350   634.31ms  1430.00us        0ms   263.00us     6.78ms   625.83ms        0ms        0ms
-total-              -   640.86ms  1324.00us        0ms   304.00us     7.62ms   631.61ms        0ms        0ms
qostest-wid23..  23350   640.86ms  1324.00us        0ms   304.00us     7.62ms   631.61ms        0ms        0ms
-total-              -   659.83ms  1357.00us        0ms   303.00us     7.50ms   650.67ms        0ms        0ms
qostest-wid23..  23350   659.83ms  1357.00us        0ms   303.00us     7.50ms   650.67ms        0ms        0ms
  • Access becomes extremely slow when opening folders or files
  • When copying the same file to different volumes, the volume with a QoS limit configured requires a longer copy time
  • SMB session disconnections may occur during periods of increased latency.
  • Virtual machines accessing the affected volume may experience prolonged login times and, in some cases, may become unresponsive.
New to NetApp?
