NetApp Knowledge Base
How to reduce the disk latency or data processing latency by volume move
1,561
Visibility:
Votes:
1
Category:
not set
Specialty:
not set
Last Updated:
Applies to
ONTAP 9
This article describes how to migrate the busy volumes to less utilized nodes/aggregates to resolve the high latency caused by CPU or Disk bottlenecks, which includes the following scenarios:
  • High latency driven by the CPU bottleneck, as discussed in ONTAP Data Processing latency - Resolution Guide
    • CPU resource is shared by all the aggregates on the same node, so CPU bottleneck can NOT be mitigated by volume migration to other aggregates on the same node.
    • The busy volumes have to be migrated to other less utilized nodes
  • High latency driven by the Disk bottleneck, as discussed in ONTAP Disk utilization and latency - Resolution Guide
    • Disk bottleneck can be mitigated by migrating the busy volumes to other aggregates on the same node, or other aggregates from a different node
    • The target aggregates for the volume migration could be less utilized aggregates with the same type of disk drives, or they could be aggregates with faster disk drives
      • For example: Moving volumes from SATA aggregates to SSD aggregates would resolve most disk bottlenecks immediately
New to NetApp?
