NetApp Knowledge Base
Volume move fails due to size larger than 100TB
406
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • Volume move
Issue
Moving a volume of size 100TB or larger fails with the following error:
Cannot move volume "test_volume" in Vserver "test_vserver" to destination aggregate "test_aggr". The aggregate - or the node that owns the aggregate - does not support a feature that is required by the source volume. Creating volume: Invalid input: Request to create volume failed because the given volume size is greater than the maximum size. Select a size of at most 100TB for the new volume.
New to NetApp?
