NetApp Knowledge Base
Should WAFL block reclamation scan speed be increased?
2,505
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
ONTAP 9
Answer
No, WAFL block reclamation scan speed should not be directly controlled.
  • By default, WAFL block reclamation scans are low priority and adjust automatically to avoid impacting client file operations.
  • If an operation is taking too long then you should review the systems workload.
Additional Information
Please contact NetApp Technical Support or log into the NetApp Support Site to create a technical case. Reference this article for further assistance.
