NetApp Knowledge Base
ONTAP AutoSupport (Transport SMTP) Delivery Failure Resolution Guide
11,846
Visibility:
Votes:
2
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • AutoSupport
  • Transport SMTP
Our NetApp node(s) doesn't appear to be sending any AutoSupport emails
  • Follow this guide to help you locate the proper solution to your question or issue.
Verify your current configuration
For a smoother experience, run the following command to gather your Nodes configuration
::>autosupport show -node <node name> -instance
Node: cluster-01
State: enable
SMTP Mail Hosts: mailhost
From Address: admin@email.com
List of To Addresses: address1@email.com,address2@email.com
List of Noteto Addresses: -
List of Partner Addresses: -
Send AutoSupport Messages to Vendor Support: enable
Protocol to Contact Support: SMTP
Support Proxy URL:
Verify Connectivity is good
cluster1::> system node autosupport check show -node node2
                            On Demand
Node             HTTP/HTTPS Server     SMTP       Configuration
node2            ok         ok         ok         ok
Connectivity fails
  • If connectivity fails, you must check connections to the Mailhost.
Procedure
How to find the reason for the failed transmission
Option 1 - Review AutoSupport History
system autosupport history show -node * -fields node ,seq-num ,status ,error ,destination
seq-num destination status error
39      http        ignore ""
39      smtp        transmission-failed  Failed sending data to the peer
39      noteto      ignore ""
38      http        ignore ""
38      smtp        sent-successful ""
38      noteto      ignore ""
Option 2 - Review notifyd.log
node run -node (node name) -command rdfile /etc/log/mlog/notifyd.log
  1. copy it out to your favorite text editor
  2. To locate the error: Use ctrl F and search
In most cases you may start from the following line (message: Closing connection #0) and work up to the true error message.
Tip: Use the following Table for additional messages to look for
SMTP Error
Solution
  • Sent-successful
    • ONTAP will consider an AutoSupport message sent-successful once it has determined that the SMTP (mailhost) server has accepted the e-mail message.
    • The message, however, might have been dropped by your mailhost server and never relayed to NetApp.com
  • [WARNING: UNSCANNABLE EXTRACTION FAILED]
  • Failed to connect to support.netapp.com port 443: Operation timed out
  • message: Could not resolve host: support.netapp.com
  • Failed sending data to the peer
  • message: 530 5.7.57 SMTP; Client was not authenticated to send anonymous mail during MAIL FROM
  • message: 550 5.1.7
  • message: 550 5.7.1 Unable to relay
  • 554 5.7.1 : Client host rejected: Access denied
  • READMSG:550 5.7.1 <autosupport@netapp.com>...Relaying denied
  • message: 553 Authentication is required to send mail as
  • 553 5.7.1 myemail@company.com: Sender address rejected: not logged in)
  • message: 553 Specified domain is not allowed
  • READMSG:554 Mail from user _@domain.com rejected for policy reasons
this is the 'from address'. mailhost  relaying policies are not allowing this account to relay
  • message: 550 5.7.606 Access denied, banned sending IP
  • message: 550 5.7.0 Message Size Violation
  • message: 550 5.7.0 Attachment Violation
  • 451 5.7.3 STARTTLS is required to send mail
  • 530 5.7.0 Must issue a STARTTLS command first
  • error message: FTP: weird server reply
  • 421 Service Not Available
  • A denial of service protection limit was exceeded.
Additional Information
SMTP Setup and Configuration
