NetApp Knowledge Base
How to create a proactive technical support case for a ONTAP upgrade
5,354
Visibility:
Votes:
8
Category:
ontap-9
Specialty:
core
Last Updated:
6/23/2025, 7:05:39 AM
Applies to
  • ONTAP 9
  • Proactive Upgrade
  • NetApp Cloud Volumes ONTAP
  • There is no need to open a NetApp Support case for an ONTAP upgrade
  • However, business requirements of change control might necessitate the creation of a NetApp technical support case for a proactive ONTAP upgrade window
Procedure
Create a Proactive Upgrade case
  1. Browse to the NetApp Support site.
  2. On the right side of the page is the assisted support pane.
  3. Select the Elio Proactive ONTAP upgradeicon.
  4. From the Elio Can Help menu select Report my upcoming maintenance in the top field.
  5. In the second field select ONTAP Upgrade.
  6. In the final field enter a serial number of a controller within the ONTAP cluster being upgraded.  There is a link to Look up serial number if needed.
  7. Click on the Submit button.
  8. Elio will confirm the request is for upcoming planned maintenance.  Click on the yes button to confirm.
  9. When Elio is complete a case will be automatically created and shown under your Cases tab of the NetApp Support menu.
  10. The case that is created is automatically closed.  This is intentional since there is no work at that time for the NetApp technical support team.
Error encountered during Upgrade
If assistance is needed during the course of the proactive upgrade, re-open the case created by Elio.
  1. Open the Cases tab on the NetApp Support menu.
  2. Re-open the case.
