NetApp Knowledge Base
Connection reset by peer when enabling certificate validation for fabricpool in MCC
242
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • Fabricpool
  • Metrocluster (MCC)
Issue
  • Enabling certificate validation for fabricpool fails as below:
cluster1::*> storage aggregate object-store config modify -object-store-name s3tiering -is-certificate-validation-enabled true
Warning: Modifying the server, port, IPspace, SSL-enabled state, or SSL/TLS certificate validation will disrupt object store access for several seconds.
Do you want to continue? {y|n}: y
Error: command failed: Object store "s3tiering" is not accessible from partner cluster in MetroCluster configuration. Reason: Cannot verify availability of the object store from node cluster2-01. Reason: Errno: Connection reset by peer.
  • Certificate has been installed on local cluster
New to NetApp?
