NetApp Knowledge Base
Before and after upgrade validation check fails to execute on shelves and sensors
12,266
Visibility:
Votes:
11
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
Issue
  • Error message occurs during validation of ONTAP upgrade:
::> cluster image show-update-progress
                                              Estimated         Elapsed
Update Phase         Status                   Duration        Duration
Pre-update checks    failed                   00:10:00        00:04:21
Details:
Pre-update Check     Status            Error-Action
Shelves and Sensors  Error             Error: Validation check failed to
check                                  execute properly.
                                       Action: If the problem persists after
                                       retrying, delete the package and
                                       download again
  • May also see an error about CPU utilization:
                                       Action: Ensure CPU utilization is
                                       less than 50%
by running the "node
                                       run -node <nodenames> -command
                                       sysstat -c 10 3" command and then try
                                       the validation again using the
                                       "cluster image validate" command. If
                                       the problem persists after retrying,
                                       contact technical support for
                                       assistance.
  • Takeover/Giveback of issued node doesn't resolve the issue.
New to NetApp?
