NetApp Knowledge Base
Available space is reported as less than expected for a thin provisioned volume
1,300
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • Thin provisioned volumes
Issue
  • It is normally expected that the volume available size =  total size - used size, however, for a thin provisioned volume sometimes the available size is reported as less than the value of (total size - used size).
cluster1::> df -h
Filesystem               total       used      avail    capacity  Mounted on                 Vserver
/vol/vol1/               972GB       200GB     524GB    20%       /vol1                      svm1
/vol/vol1/.snapshot      0           0         0        0%        /vol/vol1/.snapshot        svm1
or
cluster1::> df -h
/vol/vol2/               825GB       42GB      0        5%        /vol/vol2                  svm1
/vol/vol2/.snapshot      0           0         0        0%        /vol/vol2/.snapshot        svm1
  • If the capacity is less than 5%, the following event appears.
[XXXX: wafl_spcd_main: monitor.volume.nearlyFull:error]: Volume XXXX is nearly full (using or reserving 95%% of space and 0%% of inodes).
  • Access denial occurs once the avail size of the volume is 0.
New to NetApp?
