NetApp Knowledge Base
AutoSupport using SMTP shows sent-successful but is not received internally or by NetApp in Clustered Data ONTAP and ONTAP 9
5,672
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • AutoSupport
  • SMTP
  • ONTAP 9
  • Clustered Data ONTAP 8
Issue
  • In the Active IQ dashboard - Autosupport section you confirm the  NOTICE logs are missing (not reaching NetApp)
  • From the command line Autosupport history show confirms that all logs are sent-successful
Destination for This AutoSupport Trigger Event Time of Last Update Status of Delivery
SMTP callhome.performance.data 4/10/2020 00:20:46 sent-successful
SMTP callhome.management.log 4/10/2020 00:31:06 sent-successful
SMTP callhome.weekly 4/5/2020 00:16:14 sent-successful
SMTP callhome.invoke.all 4/4/2020 14:25:33 sent-successful
  • Testing connectivity from the command line also confirms connections are working
cluster1::> system node autosupport check show -node node_name
                             On Demand
Node             HTTP/HTTPS Server     SMTP       Configuration
node2            ok         ok         ok         ok
  • Error message might be returned from the SMTP server via an email with Delivery Status Notification (Failure)
New to NetApp?
