NetApp Knowledge Base
40G/100G Ethernet port does not auto negotiate with Nexus 9k cluster switch
3,592
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • 40/100G Ethernet port
  • Cisco N9K-C9336C-FX2  switch (Nexus 9336C-FX2)
Issue
  • When auto-negotiate is enabled, the Ethernet port will intermittently not link up with:
N9K-C9336C-FX2 data switch
Port speed must be hard set to come up
  • This can also occur after switch firmware upgrade
  • ONTAP will report the card link down in EMS log:
 [?]  Thu Sep 14 22:16:04 +0000 [cluster-01: intr: netif.linkDown:debug]: Ethernet e3a: Link down, check cable.
 [?]  Thu Sep 14 22:16:04 +0000 [cluster-01: intr: net.ifgrp.lacp.link.inactive:debug]: ifgrp a0a, port e3a has transitioned to an inactive state. The interface group is in a degraded state.
 [?]  Thu Sep 14 22:16:04 +0000 [cluster-01: vifmgr: vifmgr.portdown:debug]: A link down event was received on node cluster-01, port e3a.
  • From ASUP -> CLUSTER-SWITCH-INTERFACE.XML, the down port is reporting an incorrect interface speed (Mbps).
Switch Name Interface Name Interface Index Interface Type MTU Duplex Settings Interface Speed(Mbps) Adminstrative Status Operational Status Is ISL
csopslabs(FLM253004HB) Ethernet1/7 436210688 ethernetCsmacd 9216 unknown 100000 up down no
csopslabs(FLM253004HB) Ethernet1/8 436211200 ethernetCsmacd 9216 full-duplex 40000 up up no
New to NetApp?
