NetApp Knowledge Base
"sas.cable.degraded" detected due to faulty sas cable
1,137
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • SAS storage shelves
Issue
  • EMS show sas port in degraded mode.
[sas.cable.degraded:error]: Cable attached to SAS port "0a" is functioning in a degraded mode.
  • The speed of some PHYs is reduced or disabled when checked from  sysconfig -a output. Example:
slot 0: SAS Host Adapter 0a (PMC-Sierra PM8072 rev. C, SAS, <UP>)
Firmware rev: 03.08.09.00
Base WWN: 5:00a098:00f5e56:b0
Temperature: Not Available
Phy State: [0] Enabled, 6.0 Gb/s
           [1] Enabled, 12.0 Gb/s
           [2] Enabled, 3.0 Gb/s
           [3] Enabled, 12.0 Gb/s
OR
slot 0: SAS Host Adapter 0b (PMC-Sierra PM8070 rev. C, SAS, <UP>)
        Base WWN:           5:00a098:003abb6:34
        Phy State:          [4] Disabled
                            [5] Enabled, 12.0 Gb/s
                            [6] Enabled, 12.0 Gb/s
                            [7] Enabled, 12.0 Gb/s
  • The issue remains after sas cable reseat.
  • "storage port show" reports SAS port 0a as "online-degraded"
New to NetApp?
