NetApp Knowledge Base
System reporting Mixed-Path HA with switch attached NS224 shelf
495
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • NS224
  • Switch-attached
Issue
  • After hot-add of an additional switch-attached NS224 shelf nodes reporting Mixed-Path HA and DISK REDUNDANCY FAILED
  • No disks missing from sysconfig output
  • No storage faults or health alerts related to missing disks
  • AutoSupport disk-path output reports disk only seen through one NSM module
  • storage disk show -p also reports only seen through one NSM
Following output can be observed in the STORAGE-SHELF section of the ASUP after the problem occurred:
Shelf name:    0x.shelf17
Shelf id:      17
Channel:       0x
Module:        B  ★
Shelf UID:     00:a0:98:00:00:57:c9:b9
Shelf S/N:     95240000000000
Term switch:   N/A
Shelf state:   ONLINE
Module state:  OK
                 Device       Port         Negotiated    Medium       Device       Port          Negotiated   Received
Disk   Port      Max Link     Max Link     Link          Max Link     Max Lane     Max Lane      Lane         Error        Bad TLP      Bad DLLP     Uncorrectable  Correctable
Id     State     Speed        Speed        Speed         Speed        Width        width         width        Count        Count        Count        Errors         Errors
                 (GT/s)       (GT/s)       (GT/s)        (GT/s)
[   0] OK        8.0          8.0          8.0           8.0          2            2            2             0            0            0            0              0
[   1] OK        8.0          8.0          8.0           8.0          2            2            2             0            0            0            0              0
[   2] OK        8.0          8.0          8.0           8.0          2            2            2             0            0            0            0              0
[   3] OK        8.0          8.0          8.0           8.0          2            2            2             0            0            0            0              0
[   4] OK        8.0          8.0          8.0           8.0          2            2            2             0            0            0            0              0
[   5] OK        8.0          8.0          8.0           8.0          2            2            2             0            0            0            0              0
[   6] OK        8.0          8.0          8.0           8.0          2            2            2             0            0            0            0              0
[   7] OK        8.0          8.0          8.0           8.0          2            2            2             0            0            0            0              0
[   8] OK        8.0          8.0          8.0           8.0          2            2            2             0            0            0            0              0
[   9] OK        8.0          8.0          8.0           8.0          2            2            2             0            0            0            0              0
[  10] OK        8.0          8.0          8.0           8.0          2            2            2             0            0            0            0              0
[  11] OK        8.0          8.0          8.0           8.0          2            2            2             0            0            0            0              0
[  12] OK        8.0          8.0          8.0           8.0          2            2            2             0            0            0            0              0
[  13] OK        8.0          8.0          8.0           8.0          2            2            2             0            0            0            0              0
[  14] OK        8.0          8.0          8.0           8.0          2            2            2             0            0            0            0              0
[  15] OK        8.0          8.0          8.0           8.0          2            2            2             0            0            0            0              0
[  16] OK        8.0          8.0          8.0           8.0          2            2            2             0            0            0            0              0
[  17] DIS/DLL   NA           8.0          2.5           8.0          0            2            0             0            0            0            0              8192    ★
New to NetApp?
