NetApp Knowledge Base
System is in mixed path due to drawer issue
568
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • FAS/AFF systems
  • DS460C
Issue
  • After disk replacement, the new drive shows in bypassed state:
Enclosure Status: critical
Channel: 0a
Shelf: 1
Shelf Type: DS460-12
Product Serial Number: SHJHU1948000XXX
Module Type: IOM12
Disk Elements:
Element Status                  Status Bytes  Status Descriptions
34 [Bay 10]: OK                01,0A,00,00
35 [Bay 11]: CRITICAL          02,0B,00,24   BYPASSED B, FAULT REQSTD
36 [Bay  0]: OK                01,00,00,00
  • The nodes are in mixed path configuration:
::> system node run -node <node> -command sysconfig -a
NetApp Release 9.6P3
 System ID: 053813XXX (CLUSTER-01); partner ID: 053813XXX (CLUSTER-02)
 System Serial Number: 651949000XXX (CLUSTER-01)
 System Rev: E3
 System Storage Configuration: Mixed-Path
  • Replacing the IOM does not resolve the issue.
  • After replacing the disk with a spare, the issue remains with the slot.
New to NetApp?
