NetApp Knowledge Base
System disruption occurs after temporarily unable to read or write to boot device on FAS80x0 or AFF80x0
4,168
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • FAS80x0
    • FAS8020
    • FAS8040
    • FAS8060
    • FAS8080
  • AFF80x0
    • AFF8020
    • AFF8040
    • AFF8060
    • AFF8080
Issue
  • Node panics with string similar to:
Panic string: thread (g_up) on cpu 7 hung for 4001 milliseconds in process g_up on release 9.7P14 (C)
    Panic_Message: g_vfs_done(): rootfs.uzip read error - suspect boot device in process g_up on release 9.8P4 (C)
  • Prior to panic, g_vfs_done errors logged:
g_vfs_done():md0.uzip[WRITE(offset=535388160, length=8192)]error = 1
md0.uzip: UZIP(zlib) inflate() failed
g_vfs_done():md0.uzip[READ(offset=40071168, length=4096)]error = 86
vnode_pager_generic_getpages_done: I/O read error 5
vm_fault: pager read error, pid 52511 (cat) [retry 9]
md0.uzip[READ(offset=690434048, length=8192)]vm_fault: pager read error, pid 2729 (ucoreman) [retry 9]
  • During AUTOBOOT process, node may experience the following:
Starting AUTOBOOT press Ctrl-C to abort...
Could not load fat://boot0/X86_64/freebsd/image1/kernel:Device not found
ERROR: Error booting OS on: 'boot0' file: fat://boot0/X86_64/freebsd/image1/kernel (boot0,fat)
Autoboot of PRIMARY image failed. Device not found (-6)
New to NetApp?
