NetApp Knowledge Base
SPLinkDownAlert on FAS8200/A300 with SP firmware 5.8
1,604
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8200
  • AFF A300
  • Service Processor (SP) firmware version: 5.8
  • SP internal switch version:Version16-SB_XXII-ETHSW-RZL
Issue
  • System reports SPLinkDownAlert message:
Example:
Mon May 24 05:19:47 CST [Hostname: nphmd: hm.alert.raised:alert]: Alert Id = SPLinkDownAlert , Alerting Resource = SP Config raised by monitor controller
  • E0M link up, SP is online while no IP address from sysconfig -a:
Example:
Service Processor           Status: Online
  Firmware Version:   5.8
  Mgmt MAC Address:
  Ethernet Link:      down, full duplex, auto-neg complete
  Using DHCP:         no
 IPv4 configuration:
  IP Address:         unknown
  Netmask:            unknown
  Gateway:            unknown
 IPv6 configuration:         Disabled
slot 0: Gigabit Ethernet I210
  e0M MAC Address:     (auto-1000t-fd-up)
  Device Type:        1533
  Firmware Version:   3.25-5.5 0x80000674
  • SP internal switch version is Version16-SB_XXII-ETHSW-RZL.
Example from "SP-LATEST-CONFIGURATION":
Check revision of programmable devices with revision of images bundled in SP (/usr/local/bin/check_fw_revision.sh)
Versions that do not match will be printed.
Ethernet switch version
Version16 SB_XXII ETHSW RZL
New to NetApp?
