NetApp Knowledge Base
Fan "x" is running below normal RPM threshold
308
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • DS460C Shelf
  • FAN
Issue
  • Fan running below normal RPM threshold
node01::> storage shelf show -errors
Shelf Name: xx.xx
Shelf UID: xx:xx:xx:xx:xx:xx:xx:xx
Serial Number: xxxxxxxxxxxxxx
Error Type         Description
Fan                Fan "x" is running below normal RPM threshold. Fan is located in the rear of the shelf to the left.
  • STORAGE-FAULT also shows the fan as critical
Fans:
Element Status         Status Bytes  Status Descriptions
  1: CRITICAL          02,05,1F,A7
  2: OK                01,04,4A,A5
  3: OK                01,03,57,A3
  4: OK                01,02,D0,A2
  5: OK                01,03,4B,A3
  6: OK                01,02,C1,A2
  7: OK                01,03,0F,A3
  8: OK                01,02,A0,A2
  •  ENVIRONMENT shows no abnormal RPM
Shelf: x
 Cooling Unit installed element list: 1, 2, 3, 4, 5, 6, 7, 8; with error: 1
 Cooling Units by element:
   [1] 12990 RPM
   [2] 10980 RPM
   [3] 10740 RPM
   [4] 11280 RPM
   [5] 13020 RPM
   [6] 11160 RPM
   [7] 10680 RPM
   [8] 11280 RPM
New to NetApp?
