NetApp Knowledge Base
FAS2820 Unable to Start System-Level Diagnostics
139
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • NetApp FAS2820
  • ONTAP 9
  • Systems with external SAS shelves connected
Issue
  • When attempting to start system-level diagnostics during initial setup or hardware maintenance, the diag mode fails to start if SAS shelf cables are connected. The following log output is observed:
LOADER-A> boot_diags
Wait for driver loading...
[73.264215] sas: TMF task timeout for 5000c500f5897afe and not done
[114.736221] sas: TMF task timeout for 5000c500f5897afe and not done
[156.208223] sas: TMF task timeout for 5000c500f5897afe and not done
[197.680218] sas: TMF task timeout for 5000c500f5897afe and not done
[197.686648] pm80xx: rc=-5
* Loading driver timeout! ENV setup may be incomplete!! *
ls: cannot access '/sys/class/sas_phy/phy-6:4/device/port/': No such file or directory
[402.857729] Midplane not recognized after 5 retries!
  • The system may panic and reboot ONTAP directly.
[   36.140140] Kernel panic - not syncing: Fatal exception in interrupt
[   36.372966] Kernel Offset: disabled
[   36.573955] Rebooting in 60 seconds..
  • Diag mode starts successfully only after disconnecting the SAS cables.
New to NetApp?
