NetApp Knowledge Base
DS460 shelf fault reported for an open drawer
1,040
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • Ontap 9
  • DS460
Issue
  • Storage show fault shows that the shelf status is critical
    ::> node run -node <NodeName> storage show fault
    Enclosure Status: critical
    Channel: 1b
    Shelf: 54
  • In same output one of the drawers show open
    Drawers Control Module:
    Element Status                      Status Bytes  Status Descriptions
      1 [IOM12 A]    : OK                01,00,01,00   REPORT
      2 [IOM12 A]    : OK                01,00,01,00   REPORT
      3 [IOM12 A]    : OK                01,00,01,00   REPORT
      4: NOT INSTALLED     05,40,00,00
      5 [IOM12 A]    : OK                01,00,01,00 REPORT
      6 [IOM12 B]    : OK                01,00,01,00   REPORT
      7 [IOM12 B]    : OK                01,00,01,00   REPORT
      8 [IOM12 B]    : OK                01,00,01,00   REPORT
      9 [IOM12 B]    : OK                01,00,01,00   REPORT
     10 [IOM12 B]    : OK                01,00,01,00   REPORT
  • There may be other alerts for drives or  IOMs
  • This leads to disk redundancy alerts to be called out in auto supports
    HA Group Notification (DISK REDUNDANCY FAILED) ERROR
New to NetApp?
