NetApp Knowledge Base
Cluster ports e0a and e0b go down causing a CLAM panic - Power cycle does not resolve
1,634
Visibility:
Votes:
2
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • AFF A300, FAS8200
  • AFF A200, FAS2650, FAS2620
  • AFF A220, AFF C190, FAS2750, FAS2720
  • Two node cluster
  • Connectivity, Liveliness and Availability Monitor (CLAM) is enabled
    • ONTAP 9.8 or higher
    • Cluster configured with a SAN entity
Issue
  • Cluster ports e0a and e0b go down causing a takeover of one of the nodes
Tue Oct 03 11:08:31 CEST [node1: ixgbe/e0b: snmp.link.down:info]: Interface 2 is down.
Tue Oct 03 11:08:31 CEST [node1: ixgbe/e0b: netif.linkDown:info]: Ethernet e0b: Link down, check cable.
Tue Oct 03 11:08:31 CEST [node1: ixgbe/e0a: snmp.link.down:info]: Interface 1 is down.
Tue Oct 03 11:08:31 CEST [node1: ixgbe/e0a: netif.linkDown:info]: Ethernet e0a: Link down, check cable.
Tue Oct 03 11:08:32 CEST [node2: ixgbe/e0b: snmp.link.down:info]: Interface 2 is down.
Tue Oct 03 11:08:32 CEST [node2: ixgbe/e0b: netif.linkDown:info]: Ethernet e0b: Link down, check cable.
Tue Oct 03 11:08:32 CEST [node2: ixgbe/e0a: snmp.link.down:info]: Interface 1 is down.
Tue Oct 03 11:08:32 CEST [node2: ixgbe/e0a: netif.linkDown:info]: Ethernet e0a: Link down, check cable.
  • An "out of quorum" panic occurs on one of the nodes.
PANIC  : Received PANIC packet from partner, receiving message is (Coredump and takeover initiated because Connectivity, Liveliness and Availability Monitor (CLAM) has determined this node is out of quorum.
New to NetApp?
