NetApp Knowledge Base
Chassis Over Temperature Alerts Due to High Ambient Room Temperature
784
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • AFF / ASA/ AFX / FAS
  • ONTAP 9
Issue
  • The following EMS and AutoSupport messages were reported on both nodes in the cluster:
[node1:env_mgr:monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: LED2 Temp is warning high (38C).
[node1:env_mgr:monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: LED1 Temp is warning high (38C).
[node1:monitor:monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too high..
[node1:env_mgr:callhome.chassis.hitemp:error]: Callhome for CHASSIS OVER TEMPERATURE
[node2:env_mgr:monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: LED2 Temp is warning high (38C).
[node2:env_mgr:monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: LED1 Temp is warning high (38C).
[node2:monitor:monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too high..
[node2:env_mgr:callhome.chassis.hitemp:error]: Callhome for CHASSIS OVER TEMPERATURE
  • PLATFORM-SENSORS.XML:
LED1 Temp thermal warn-high 38C
LED2 Temp thermal warn-high 38C
New to NetApp?
