NetApp Knowledge Base
A400 Cross cabled cluster ports generate EMS message for unexpected remote device
294
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • AFF A400
  • ONTAP 9.10.1 and later
Issue
  • We see the following EMS message in logs. If the message repeats every few minutes, it might indicate a problem in the cluster interface configuration or the physical cabling of the switchless cluster
  • If two-node switchless A400 cluster ports are cross-cabled, remote data access might have intermittent issues due to session establishment failures
  • Additional issues on the cluster may arise due to the cross-cabled ports, and thus identifying and resolving the cross-cabled ports is the first step prior to resolving any other issues on your cluster
[cluster01-01: kernel: csm.homePortInfoUnexpected:notice]: CSM reports unexpected information for cluster LIF ID "1023" (home port: "e3b", remote device ID: "e3a").
  • Intermittent timed out alerts for NFS mounts on the servers
cluster02-02 ERROR Nblade.nfsConnResetAndClose: Shutting down connection with the client. Vserver ID is 4; network data protocol is NFS, Rpc Xid 0x0; client IP address:port is 10.120.10.19:25368. local IP address is 10.120.10.18; reason is Idle Timeout, closing connection.
New to NetApp?
