How to troubleshoot issues related to connectivity, zoning, or performance with Cisco fabric switches
Applies to
Flash Array
TECHNICAL TRIAGE TEMPLATE
Section 1: Usage
Use:
Product/Technology: Cisco Fabric Switches |
Audience: Customer/Partner/TSE unfamiliar with the Product/Technology |
This template should be used when a customer is experiencing issues in SAN and the fabric switches are being considered a possible source or contributor to the issue.
Switches might be involved if the issue is related to connectivity, zoning, or performance.
Section 2: Solutions
Cisco SAN switch documentation:
