NetApp Knowledge Base
How to troubleshoot issues related to connectivity, zoning, or performance with Cisco fabric switches
530
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
Flash Array
1030324-1.pngTECHNICAL TRIAGE TEMPLATE
Section 1: Usage
Use:
  • Refer this TTT during a new case creation on the NetApp Support site
  • It is used by TSEs/Partners when a customer calls support directly, to help frame the issue
  • Section 2 provides links to most common solutions and additional resources for the Product/Technology
  • Section 3 provides steps to gather the relevant data to open a case
Product/Technology:
Cisco Fabric Switches
Audience:
Customer/Partner/TSE unfamiliar with the Product/Technology
This template should be used when a customer is experiencing issues in SAN and the fabric switches are being considered a possible source or contributor to the issue.
Switches might be involved if the issue is related to connectivity, zoning, or performance.
Section 2: Solutions
Cisco SAN switch documentation can be accessed here
New to NetApp?
