NetApp Knowledge Base
StorageGRID fatal installation failure SANtricity OS staging failed
814
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
  • Netapp StorgageGRID 11.4 and above.
  • Netapp SANtricity OS upgrade
Issue
  • The following error message is observed for one or multiple nodes while updating the SANtricity OS:
Error: Fatal installation failure - SANtricity OS staging failed with: Failed. SANtricity OS staging failed with
return code RETCODE_ERROR.
  • The OS Upgrade can appear to be Complete but the original firmware version revision is still visible:
SANtricity OS Upgrade is not applicable to this node.
11.6 Example:
New to NetApp?
