NetApp Knowledge Base
How to reclaim space on StorageGRID after versioned objects are Deleted
835
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
  • StorageGRID
  • ONTAP
  • Fabric Pool
ONTAP issued deletes were placing a delete marker instead of actual deletes when versioning is enabled.
Object deletion and defragmentation:
  • FabricPool does not delete blocks from attached object stores. Instead, FabricPool defragments objects based on the percentage of used blocks in the object.
  • Defragmentation reclaims space that is used by blocks that have been deleted or that are no longer being referenced by ONTAP's local tier.
  • Defragmentation and deletion do not occur until less than the unreclaimed space threshold being referenced by ONTAP is met.
  • When enough (1,024) blocks have zero references, their original 4MB objects are deleted, and a new 4MB object is created.
New to NetApp?
