StorageGRID Node went unresponsive due to faulty fan
Applies to
StorageGRID
Issue
One or more services are unresponsive, or node cannot be reached.
BMC Logs reports fan failure alerts :
1842 Oct/13/2025 10:01:31 [Critical] [Fan_SYS3_1] [Fan] Lower Critical - Going Low (Reading: 0 RPM/ Threshold: 500 RPM) - Asserted
1841 Oct/13/2025 10:01:20 [Information] [Fan_SYS3_1] [Fan] Lower Critical - Going Low (Reading: 600 RPM/ Threshold: 500 RPM) - Deasserted
1840 Oct/13/2025 10:00:56 [Information] [Login Info] [Login success] Login success -- Account: root/ IP:0.0.0.0
1839 Oct/13/2025 09:57:54 [Critical] [Fan_SYS3_1] [Fan] Lower Critical - Going Low (Reading: 0 RPM/ Threshold: 500 RPM) - Asserted
1838 Oct/13/2025 09:57:46 [Information] [Fan_SYS3_1] [Fan] Lower Critical - Going Low (Reading: 700 RPM/ Threshold: 500 RPM) - Deasserted
1837 Oct/13/2025 09:52:13 [Critical] [Fan_SYS3_1] [Fan] Lower Critical - Going Low (Reading: 0 RPM/ Threshold: 500 RPM) - Asserted
1836 Oct/13/2025 09:52:05 [Information] [Fan_SYS3_1] [Fan] Lower Critical - Going Low (Reading: 700 RPM/ Threshold: 500 RPM) - Deassertedbase-os-logs/var/log/messages reports below events: Oct 11 16:56:03 localhost kernel: [8319465.642907] pcieport 0000:5d:00.0: pciehp: Slot(65-1) Powering on due to button press
Oct 11 16:56:03 localhost kernel: [8319465.642905] pcieport 0000:5d:00.0: pciehp: Slot(65-1): Attention button pressed
Oct 11 16:56:03 localhost kernel: [8319465.642894] pcieport 0000:5d:00.0: pciehp: Slot(65-1): No link
Oct 11 16:56:01 localhost kernel: [8319464.188299] pcieport 0000:17:01.0: pciehp: Slot(19-1): Card present
Oct 11 16:56:01 localhost kernel: [8319464.180347] pcieport 0000:17:01.0: pciehp: Slot(19-1): Card not present
