NetApp Knowledge Base
StorageGRID storage node reports Low metadata storage with abnormal disk space used
148
Visibility:
Votes:
0
Category:
storagegrid-webscale
Specialty:
sgrid
Last Updated:
Applies to
  • NetApp StorageGRID
  • Bare-metal node
  • Redhat Linux
Issue
  • Low metadata storage alert active in StorageGRID UI for affected node and shows over 800% disk space used
  • In Grid Topology > Node > DDS > Data Store reports:
  • df -h outputs shows volumes on affected node have improper capacity size:
/dev/sdc       200G  102G   98G  52%/var/local/rangedb/0
/dev/sdd       90G   68G   22G  76%/var/local/rangedb/1
/dev/sde       6.7T  3.6T  3.1T  54%/var/local/rangedb/2
/dev/sdf       6.7T  2.4T  4.3T  36%/var/local/rangedb/3
/dev/sdg       90G   65G   26G  72%/var/local/rangedb/4
/dev/sdh       200G   71G  130G  36%/var/local/rangedb/5
/dev/sdi       6.7T  3.4T  3.3T  51%/var/local/rangedb/6
/dev/sdj       6.7T  3.0T  3.7T  45%/var/local/rangedb/7
/dev/sdk       6.7T  2.6T  4.1T  39%/var/local/rangedb/8
/dev/sdl       6.7T  2.8T  3.9T  43%/var/local/rangedb/9
/dev/sdm       6.7T  3.1T  3.6T  47%/var/local/rangedb/A
New to NetApp?
