NetApp Knowledge Base
StorageGRID Low Metrics Disk Capacity - AutoSupport Message
280
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
NetApp StorageGRID
Event Summary
StorageGRID reports LowMetricsDiskCapacity indicating the space available for the metrics database is low.
Validate
  1. Login to the Primary Admin node with SSH
  2. Run df -h
  3. Verify space usage under /var/local/mysql_ibdata
  4. Run storagegrid-status command and verify the status of the prometheus service
Resolution
  1. If running StorageGRID 11.6.0.2 or earlier, upgrade to 11.6.0.3 or higher
  2. Contact NetApp Technical Support if the available space continues to decrease and above articles are not applicable.
Additional Information
Add your text here.
