NetApp Knowledge Base
StorageGRID Appliance NIC fault detected - AutoSupport Message
526
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
  • NetApp StorageGRID
  • Software release 11.7 +
Event Summary
  • StorageGRID Grid Manager reports the following alert: Appliance NIC fault detected – A problem with a network interface card (NIC) in the appliance was detected.
  • ASUP generated Alert in case:
StorageGRID Notification from GRIDID(HARDWARE FAILURE - Component: NIC, Slot: hic3, PartNumber: X1158A)
nicName: hic3, nicDescription: ConnectX-6 Lx EN adapter card, 25GbE, Dual-port SFP28, PCIe 4.0 x8, No Crypto, nicSerialNumber: MTXXXXXXXX3R, nicFirmwareVersion: 26.39.1002 (MT_0000000531), componentMarketingPartNumber: X90-SG6000-HBA-FC, component3x5PartNumber: 106-00289, hardwarePlatform: SGF6112
Validate
  1.   Login to the StorageGRID Grid Manager, and confirm the following alert is present:
  1. Verify what errors are seen on hic with following commands.
    1. ifconfig <hic>
    2. ethtool -S <hic>
Resolution
  1. Within StorageGRID Grid Manager, navigate to Support > Diagnostics > Appliance hardware component temperatures and look for the NIC components.
    • The address for the NIC ports are as follows:
      • 0000:30:02_0_0000:31:00_0
      • 0000:30:02_0_0000:31:00_1
      • 0000:b0:02_0_0000:b1:00_0
      • 0000:b0:02_0_0000:b1:00_1
  2. If above alerts are found, please follow the instructions under "NetApp StorageGRID NIC fault detected and temperature warning alert triggered" to address the issue.
  3. If above steps do not resolve the issue, then you may attempt a reseat of the NIC.
    • Refer to the maintenance instructions for your appliance for detailed steps.
  4. The solution might require a part replacement. Please contact NetApp Technical Support or log into the NetApp Support Site to create a case. Reference this article for further assistance.
Additional Information
Please refer to the appropriate hardware procedure guide for your appliance:
