Appliance DAS Drive Exceeding Limit is reported after StorageGRID nodes expansion
Applies to
- StorageGRID 11.9
- Older storage node appliances are scheduled to be replaced with new appliances
Issue
- After expanding StorageGRID nodes, new storage nodes report the following alert:
Appliance DAS drive exceeding limit for data written per day (6 alerts)An excessive amount of data is being written to a drive each day, which might void its warranty.
Recommended actionsThis alert is triggered if the number of bytes written to a drive per day would cause the Total Bytes Written (TBW) limit to be reached before the end of the warranty.Determine why the drive is receiving a large amount of data each day. Review any recent changes that might increase the load on the appliance Storage Node. For example, did you activate a new ILM policy? Are you using a new erasure-coding profile? Have you added new S3 clients?For more details on SSD warranty endurance, go to Support > Tools > Metrics and select "SSD Warranty" under Grafana.If this is an expected burst that will not continue indefinitely, you can ignore this alert.
- Support > Tools > Metrics > SSD Warranty >
Bytes written per dayshows all the new storage nodes with a higher value than old storage nodes.
NOTE: Threshold for Bytes written per day is 1.92 TB/day
