NetApp Knowledge Base
Appliance DAS drive fault detected on StorageGRID service appliance
227
Visibility:
Votes:
0
Category:
storagegrid-webscale
Specialty:
sgrid
Last Updated:
Applies to
  • NetApp StorageGRID
  • SG100/SG1000/SG110/SG1100/SG6112 service appliance
Issue
  • StorageGRID UI reports alert: Appliance DAS drive fault detected. A problem was detected with a direct-attached storage (DAS) drive in the appliance
  • In Grid Manager > Help (?) > API Documentation > alerts > GET > Try it out lists the affected Slot:
"alertname": "Appliance DAS drive fault detected",
"firmware_version": "XXXX",
"instance": "admin_node_name",
"job": "miscd",
"model_name": "XXXXX",
"name": "nvme1n1",
"node_id": "1XXXXX",
"serial_number": "XXXXX",
"severity": "critical",
"site_id": "XXXX",
"site_name": "site_name",
"slot": "HDD03",
"x_part_number": "H610S-SSD-960GB-B"
  • A new support case may be automatically opened by AutoSupport with the following title.
StorageGRID Notification from xxxxx (HARDWARE FAILURE - Component: SSD, Slot: HDD03, PartNumber: X4131A)
New to NetApp?
