NetApp Knowledge Base
SRAM dump with reinitialization failed leaves adapters offline
646
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
san
Last Updated:
Applies to
Ontap 9.x
Issue
  • EMS logs reports reinitialization failed:
Thu Mar 16 16:59:55 -0400 [SAN01: fct_tpd_thread_3: scsitarget.fcp.dump:debug]: FCP target SRAM dump generated for adapter 1d, FW Initiated Dump
Thu Mar 16 16:59:55 -0400 [SAN01: fct_tpd_thread_3: scsitarget.hwpfct.errorReset:notice]: An error was encountered in the FC target driver on Fibre Channel target adapter 1d. The adapter will be automatically reset to clear the status:0x87000000, status1:0x742f, status2:0x0, DIP:1, RN:1, RDY:0, Dump owner:3 condition.
Thu Mar 16 16:59:55 -0400 [SAN01: fct_tpd_thread_2: scsitarget.hwpfct.errorReset:notice]: An error was encountered in the FC target driver on Fibre Channel target adapter 1c. The adapter will be automatically reset to clear the status:0x87000000, status1:0x742f, status2:0x0, DIP:1, RN:1, RDY:0, Dump owner:3 condition.
Thu Mar 16 17:00:56 -0400 [SAN01: fct_tpd_thread_3: fcp.io.status:debug]: STIO Adapter 1d resetting with 5 ITNs and 6 commands to drain
Thu Mar 16 17:01:26 -0400 [SAN01: fct_tpd_thread_3: scsitarget.hwpfct.errorReset:notice]: An error was encountered in the FC target driver on Fibre Channel target adapter 1d. The adapter will be automatically reset to clear the port offline failed, rc:-1 condition.
Thu Mar 16 17:01:57 -0400 [SAN01: fct_tpd_thread_2: scsitarget.hwpfct.errorReset:notice]: An error was encountered in the FC target driver on Fibre Channel target adapter 1c. The adapter will be automatically reset to clear the status:0x87000000, status1:0x742f, status2:0x0, DIP:1, RN:1, RDY:0, Dump owner:3 condition.
Thu Mar 16 17:02:00 -0400 [SAN01: fct_tpd_thread_3: fcp.io.status:debug]: STIO Adapter 1d reinitialization failed, saving RAS trace data.
  • Depletion of Driver MQ condition error  reported in ems logs:
Thu Nov 30 12:24:56 0000 [efnexxxb-n2: fct_tpd_thread_0: scsitarget.hwpfct.errorReset:notice]: An error was encountered in the FC target driver on Fibre Channel target adapter 2a. The adapter will be automatically reset to clear the Depletion of Driver MQ condition.
Thu Nov 30 12:24:56 0000 [efnexxxb-n2: fct_tpd_thread_0: fcp.io.status:debug]: STIO Adapter 2a resetting with 0 ITN and 0 commands to drain.
Thu Nov 30 12:24:56 0000 [efnexxxb-n2: fct_tpd_thread_1: scsitarget.hwpfct.errorReset:notice]: An error was encountered in the FC target driver on Fibre Channel target adapter 2b. The adapter will be automatically reset to clear the Depletion of Driver MQ condition.
  • Port status show OFFLINED BY SYSTEM
slot 2: Fibre Channel Target Host Adapter 2a
                (Emulex LPe32000 (LPe32004) rev. 12, <OFFLINED BY SYSTEM>)
                Board Name:        111-0xx48
                Serial Number:     FP1046xx14
                Firmware rev:      12.2.390.0
                Host Port Addr:    000000
                FC Nodename:       50:0a:0x:8x:8x:cx:4e:35 (500a0x8x8xcx4e35)
                FC Portname:       50:0a:0x:8x:8x:cx:4e:35 (500a0x8x8xcx4e35)
                Connection:        No link
                Switch Port:       sgs2xx11:16
  SFP Vendor Name:   AVAGO (Warning: SFP info not updated when port is OFFLINE)
  SFP Capabilities:  8, 16, 32 Gbit/Sec
New to NetApp?
