NetApp Knowledge Base
Verification and cloning Failed to clone resources because of SVM-DR
228
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Plug-in for SQL 6.0 (SCSQL)
  • SnapCenter
Issue
  • Verification job failing with the following error messages:
Failed to clone resources, error isMount operation failed with error Failed to mount storage resource, error is Failed to create the volume clone.
Object reference not set to an instance of an object.
, Failed to create the volume clone.
  • In the job log, the SMCore file indicates:
ERRORSMCore_3748367 PID=[14920] TID=[124] Activity (Cloning Resources) of Workflow(SnapMgrCoreService.SmJobActivity), Failed with error: Failed to cloneresources, error isMount operation failed with error Failed to mount storageresource, error is Failed to create the volume clone.
DEBUG SMCore_3748367 PID=[14920] TID=[124] Activity name: Cloning snapshot <snapshotname>_<timestamp>: -1 - Mountoperation failed with error Failed to mount storage resource, error is Failedto create the volume clone.Objectreference not set to an instance of an object.
, Failed tocreate the volume clone.
  • In the ASUP audit log, the following information indicates that the command is connected via the SVM and then try to contact the SVM-DR name:
Thu Oct 03 2024 12:45:09 +00:00 [kern_audit:info:3177] 8503e80000311e18 :: :http :: : :: <SVM>:user:: POST /api/private/cli/volume/clone : {"vserver":"<SVM-DR>","flexclone":"","parent-snapshot":"","parent-volume":"","foreground":true,"snaplock-type":"non-snaplock","junction-active":true,"junction-path":"/"} :: Error: Specified Vserver not found
New to NetApp?
