NetApp Knowledge Base
Unable to perform SCO operation - Unexpected Error
2,928
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
SnapCenter Plug-in for Oracle Databases (SCO) - All versions
Issue
  • Scheduled SCO clone lifecycle job fails with following error in SC UI:
Failed to delete backup as there are clone(s) created from this backup. Please delete clone(s)
  • SCO clones cannot be deleted with error:
PL-SCO-20032: canExecute operation failed with error: PL-SCO-30001: Database SID "example" already exists, there may be an existing database defined with this SID
  • Discovery of the Database fails with:
An exception thrown during the execution of method findDatabaseVersion and the exception message is Operation Exception occured during oracle databaseconnection, reason: Unexpected Operation occured.
PL-SCO-20006: Discovery of database files failed for database
PL-SCO-20036: Discovery of database instance <ORASID> failed with error: Operation Exception occured during oracle databaseconnection, reason: Unexpected Operation occured.
  • But mainly the following error is seen:
c.n.c.r.RemoteObjectFactoryFactory - REMOTE-00001: Unable to connect to spawned helper process.
./../plugins/sco/bin/launch-java: line 36:/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.342.b07-2.el8_6.x86_64/jre/bin/java: No such file or directory
New to NetApp?
