NetApp Knowledge Base
SnapCenter Backups start failing and require a SC Server reboot
375
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Server (SC) 4.4
  • SnapCenter Plug-In for SQL (SCSQL) 4.4
Issue
All SCSQL backups stop working and you may see errors similar to the ones below, in the Event Viewer of the SC Server:
Log Name:      Application
Source:        SceCli
Date:          19/05/2021 15:34:27
Event ID:      1202
Task Category: None
Level:         Warning
Keywords:      Classic
User:          N/A
Computer:      SNAPCENTER.domain.com
Description:
Security policies were propagated with warning. 0x57 : The parameter is incorrect.
Log Name:      System
Source:        Microsoft-Windows-DistributedCOM
Date:          19/05/2021 15:55:02
Event ID:      10016
Task Category: None
Level:         Error
Keywords:      Classic
User:          MYDOMAIN\snapcenter
Description:
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
{D63B10C5-BB46-4990-A94F-E40B9D520160}
and APPID {9CA88EE3-ACB7-47C8-AFC4-AB702511C276}
to the user MYDOMAIN\snapcenter SID (S-1-5-00-00000-00000-00000-000001) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable).  This security permission can be modified using the Component Services administrative tool.
Log Name:      System
Source:        Microsoft-Windows-WAS
Date:          19/05/2021 16:03:23
Event ID:      5010
Task Category: None
Level:         Warning
Keywords:      Classic
User:          N/A
Description:
A process serving application pool 'SnapCenter' failed to respond to a ping. The process id was '7576'.
New to NetApp?
