NetApp Knowledge Base
SnapCenter 6.X Install Fails at Pre-requistes Validation
1,300
Visibility:
Votes:
1
Category:
not set
Specialty:
snapx
Last Updated:
6/29/2025, 11:19:25 PM
Applies to
  • SnapCenter Server 6.0 (SC 6.0)
  • SnapCenter Server 6.1 (SC 6.1)
  • SnapCenter Plug-In for Windows (SCW)
  • SnapCenter Plug-In for SQL (SCSQL)
  • SnapCenter Plug-In for Exchange (SCE)
Issue
  • Attempting to install or upgrade SnapCenter 6.X comes with an error about .NET 8.0 Windows Server:
  • Alternatively, one of the following messages may appear
Microsoft .NET 8.0 - Windows Server Hosting -> IIS module is missing. Repair of Microsoft .NET 8.0.8 - Windows server hosting is required.
500 - Internal server error.
There is a problem with the resource you are looking for, and it cannot be displayed
  • SCW plugin upgrade or install fails with a generic error (MSI installation error code 1603).
  • Error logged in the SnapCenter_Windows_Host_Plug-in_Install_XXXX.log:
Engine: property 'ASP_NETCORE_VERSION' value now '9.x.x'
(CLR Action): Highest available runtime: v4.0.30319
(CLR Action): Trying to use highest runtime...
(CLR Action): Using highest version runtime...
(CLR Action): SWInstallerHelper.CheckForRollbackLogs: SETUP_ERROR: Failed Plugin: SnapCenter Plug-in for Microsoft Windows
(CLR Action): SWInstallerHelper.CheckForRollbackLogs: SETUP_ERROR: MSI Errorcode: 1603
  • SCSQL plugin upgrade or install fails with a generic error (MSI installation error code 1603).
1-13-2025[04:17:17 PM]: (CLR Action): Highest available runtime: v4.0.30319
1-13-2025[04:17:17 PM]: (CLR Action): Trying to use highest runtime...
1-13-2025[04:17:17 PM]: (CLR Action): Using highest version runtime...
1-13-2025[04:17:17 PM]: (CLR Action): SWInstallerHelper.CheckForRollbackLogs: SETUP_ERROR: Failed Plugin: SnapCenter Plug-in for Microsoft SQL Server
1-13-2025[04:17:17 PM]: (CLR Action): SWInstallerHelper.CheckForRollbackLogs: SETUP_ERROR: MSI Errorcode: 1603
  • SCE plug-in upgrade or installation fails with the following errors seen:
  • SnapCenter_Windows_Host_Plug-in_Install_<JobID>.log
(ISP Action): A program failed to start.\nTrying to start a program resulted in an error.\nProgram location: \nProgram: "vssproviders\navssprv.exe"\nCommand line: -r service -a ".\LocalSystem"\n\nGetLastError returned: 0.
(ISP Action): RegisterVSSProvider: Register VSS Provider Result (Post Config Validation): -2147024894 .
(ISP Action): LaunchProgram: LaunchApplication Program exit code: 2, Exit message: The system cannot find the file specified.
(ISP Action): RegisterVSSProvider: ERROR: Failed to Configure the VSS Provider
New to NetApp?
