NetApp Knowledge Base
CXPLAT-215: RFE: SCV should remove requirement for built-in domain administrator account for Guest File Restore on Windows VMs
155
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Issue
Error messages trying to run Guest File Restore:
Failed to access guest system using specified credentials.
Please verify VMWare tools is installed/running on the system and account used has domain administrator privileges.
Error is ApiException Failed to start process in guest system SystemError vix error codes = (3004, 0).
Seen in {}vmcontrol_jetty_server.log{}:
com.netapp.nvpf.api.model.ApiException: Failed to access guest system using specified credentials.
Verify if VMWare tools is installed or running on the system and the account is built-in administrator account. Error is ApiException  Failed to start process in guest system InvalidGuestLogin
New to NetApp?
