NetApp Knowledge Base
CXPLAT-1623: SCV 6.1 backup fails even if non-NetApp storage is not selected in Spanning disks
231
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Issue
  • SnapCenter Plug-in for VMware vSphere (SCV) 6.1, 6.1P1, or 6.2 backups for VMs with VMDKs on NetApp and non-NetApp storage fail even if non-NetApp storage is not selected in Spanning disks using Manually select the spanning datastores or Always exclude all spanning datastores.
  • vmcontrol_[JOB_ID].log shows errors:
ERROR scv --- [p1738236591-475] c.n.a.s.c.SnapManagerStorageServiceImpl  : Failed to get the storage system for host resource : Name : /non-netapp-nfs, Type: SDNASDir
ERROR scv --- [p1738236591-475] c.n.a.m.DatastoreStorageDetailsCache     : Failed to get the storage system for host resource : Name : /non-netapp-nfs, Type: SDNASDir
ERROR scv --- [p1738236591-475] c.n.a.s.p.DiscoverResourcesManager       : [JobId:xxx] com.netapp.nvpf.api.model.ApiException: Failed to get the storage system for host resource : Name : /non-netapp-nfs, Type: SDNASDir
ERROR scv --- [p1738236591-475] c.n.a.s.p.DiscoverResourcesManager       : Encountered error while processing discover resources. Error: Failed to get the storage system for host resource : Name : /non-netapp-nfs, Type: SDNASDir
  • Backups for the same resource group succeeded in previous versions of SCV, such as SCV 4.9.
New to NetApp?
