NetApp Knowledge Base
CSNAPC-8713: "Import-Module SnapDrive" is not mentioned in SnapCenter Cmdlet Reference Guide
158
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Issue
SnapCenter Cmdlet Reference Guide 6.0 or later mentions running Import-Module SnapCenter -DisableNameChecking,
but SnapDrive cmdlets (such as Get-SdInfo, Connect-SdStorage, etc.) fail with error even after running it:
The term '<cmdlet>' is not recognized as a name of a cmdlet, function, script file, or executable program.
Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
Note: The SnapDrive cmdlets are described as SnapCenter Windows disk management cmdlets in the reference guide.
New to NetApp?
