NetApp Knowledge Base
CSNAPC-7115: RFE: Make SnapCenter Server/Plug-in REST API usage setting available from Powershell
126
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Issue
At the moment, to disable REST API in case certain functionality doesn't work correctly, the SMCoreServiceHost.exe.config (up to version 5.0) or the SMCoreServiceHost.dll.config (6.0 and higher) needs to be edited.
The editing requires a service restart which can disrupt running jobs, while a Powershell command can make sure that the service is updated with the change while running live.
New to NetApp?
