NetApp Knowledge Base
CSNAPC-6502: SnapCenter 6.0 generates psd1, psm1, and ps1xml files in %TEMP% directory when running SCSQL backup job with MSCS
99
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Issue
  • Directory remoteIpMoProxy_FailoverClusters_2.0.0.0_localhost_XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX hosting {}.psd1{}, {}.psm1{}, and .ps1xml files is created in %TEMP% of SnapCenter administrator user on the plug-in host when running SnapCenter Plug-in for Microsoft Windows (SCW) backup job with Windows Server Failover Cluster (WSFC).
  • The directory has the following 3 files:
FailoverClusters.psd1
remoteIpMoProxy_FailoverClusters_2.0.0.0_localhost_XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX.format.ps1xml
remoteIpMoProxy_FailoverClusters_2.0.0.0_localhost_XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX.psm1
  • The files and directory accumulate and consume disk space because they are not removed even after a backup job is completed
New to NetApp?
