NetApp Knowledge Base
CSNAPC-3980: Audit Log Integrity Check fails with duplicate audit id found in the file audit.log
202
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Issue
The following error happens when run Audit integrity check from [settings=>Global settings=>Audit log settings=>Click Start integrity check]
[Audit Id: [xxxxxxxx].
Reason: Duplicated Audit Id found in the file audit.log. at YYYY-MM-DDTHH:MM:SS.μs+00:00 and YYYY-MM-DDTHH:MM:SS.μs+00:00
Audit Id: [xxxxxxxxx].
Reason: Duplicated Audit Id found in the file audit.log. at YYYY-MM-DDTHH:MM:SS.μs+00:00 and YYYY-MM-DDTHH:MM:SS.μs+00:00]
New to NetApp?
