NetApp Knowledge Base
CSNAPC-11455: DB2 database discovery fails with access error for .sc file
212
Visibility:
Votes:
1
Category:
snapcenter
Specialty:
snapx
Last Updated:
Issue
Auto-discovery fails in a new installation of SnapCenter Plug-in for DB2 with the following errors:
2026-05-13T09:48:23.2710000+02:00 DEBUG [pool-16-thread-1] 111 com.netapp.snapcenter.plugin.DB2.DB2Logger -DB2 command file: '/var/opt/snapcenter/scc/scc_20260513094823131.sc' 2026-05-13T09:48:23.2710000+02:00 DEBUG [pool-16-thread-1] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger -Starting execution of the command : [/bin/sh, -c, sudo /opt/NetApp/snapcenter/scc/bin/sccCommandExecutor testins '\"sqllib/bin/db2\" -tf \"/var/opt/snapcenter/scc/scc_20260513094823131.sc\"'] 2026-05-13T09:48:24.7460000+02:00 DEBUG [Thread-66] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger -DB21005E An error occurred while accessing the file error_message SCC-00175: Auto Complete Discovery for plug-in [DB2] failed with error [Operation [DISCOVERCOMPLETE] failed with Exception [java.util.concurrent.ExecutionException: com.netapp.snapcenter.plugin.common.PluginException: java.lang.Exception: Unable to parse sql output.]] and exit code [1]. Exiting.
New to NetApp?
