NetApp Knowledge Base
CAIQUM-7114: Cluster addition or monitoring failing in AIQUM 9.14+ with CA signed certificate and cloud agent enabled
3,786
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Issue
  • In the scenario where AIQUM 9.14+ is using CA signed certificate on port 443, Cloud agent is enabled in server.properties file, and ONTAP in 9.14 or higher, cluster addition and collections fail with Cloud agent connection error
  • server_acq.log:
    ERROR [acq-facade-init-thread-ds-2] c.n.u.CloudAgentConnectionUtil (CloudAgentConnectionUtil.java:254) - Establishing connection with cluster <cluster_ip> failed
    ERROR [acq-facade-init-thread-ds-1] c.n.u.CloudAgentConnectionUtil (CloudAgentConnectionUtil.java:223) - Failed to establish connection for cloud agent instance "UnifiedManager<aiqum_system_id>". Reason: Certificate error: self-signed certificate in certificate chain._
    ERROR [acq-facade-init-thread-ds-1] c.n.u.CloudAgentConnectionUtil (CloudAgentConnectionUtil.java:254) - Establishing connection with cluster <cluster_ip> failed
  • ONTAP EMS event:
    mhost.ca.connect.failure: Cluster agent connection of the client: UnifiedManager_<aiqum cert-serial-num> is not healthy. Attempting to reconnect. Error: Certificate error: self-signed certificate in certificate chain.
  • As soon as AIQUM uses a self-signed certificate, REST collections will continue to work
  • The issue is only present in the scenario where CA signed cert is used on AIQUM and Cloud agent is enabled for REST collections
New to NetApp?
